Need Parts used source for 1850
Fred Miller
11-26-2001 19:13:14
Hi,
We are trying to locate a used ring and pinion gear in good condition for an 1850. Can anyone supply a good source for used Oliver parts?
Thanks in advance,
Fred Miller
JDP
11-27-2001 15:40:44
 Re: Need Parts used source for 1850 in reply to Fred Miller, 11-26-2001 19:13:14
Try Maibach Tractor at 1-800-808-9934. They have a lot of used parts for 1850's, as well as other Olivers. They are located in Ohio.
terry
11-26-2001 21:41:35
where are you located? there is one yard here in Wisconsin devoted to the Olivers that should have your part. I remember seeing the ad in the WI State Farmer. I also located what I believe to be the back half of an 1850 and will be taking some gears out. I can see if what you want is still there.
