WHAT IS THIS ?
JIM
11-22-2001 13:58:27
WHAT IS THIS OLIVER SL#8117-518
D13
11-23-2001 03:47:18
 Re: WHAT IS THIS ? in reply to JIM, 11-22-2001 13:58:27
An early S55 will have a round nose, grille with horizontal openings, a metal strip with OLIVER running top to bottom on the grilee (note: this is aluminum). Both the gas cap and the radiator cap will be hidden under the hood trip panel on top. Later S55 will have the gas cap exposed.
550's share most of the same parts, but the grill is squared off. The OLIVER emblem is an oval above the grill. Early ones have horizontal openings (like a 880) later have the checkerboard, made of fiberglass.
The White 2-44 is the same tractor with a new grille.
My S55 was born a loader tractor and never had a PTO, so that is unusual but not uncommon. Farmers with ground drive equipmnet bought these for cleaning out barns and did not spend the extra money for the PTO. CHeck under the rear axles for a clean patch that might indicate yours has had a loader.
I have seen numerous hybrids, in fact I am contemplating repowering a seized 550 chassis with my running S55 motor in it, and taking the S55 loader and installing it, then parting the rest of my S55 out. If the trans is bad on the 550 I may keep my S55 and just swap the steering and brakes, and install the 550 PTO into the S55.
If it is a S55 with just 550 sheet metal, it would make a nice restoration project.
Larry
11-22-2001 14:02:12
It should be from a Super 55.
Larry
11-22-2001 14:04:41
 Re: Re: WHAT IS THIS ? in reply to Larry , 11-22-2001 14:02:12
1954 year.
JIM
11-22-2001 15:35:44
 Re: Re: Re: WHAT IS THIS ? in reply to Larry, 11-22-2001 14:04:41
THAT IS WHAT I HAVE BEEN TOLD BUT WAS NOT SURE IT DOSE NOT HAVE A P.T.O. AND IT DOSE NOT LOOK LIKE THE SUPER 55'S BUT IS THE SAME SIZE.
