White 2-85 hydraulics overheating
Dexter
02-11-1999 17:40:04
Can anyone give me information about the problem with the White tractors hydraulic system? I have a White 2-85 with a hydraulic oil cooling system. Yet when I work my tractor lightly(not even using the hydraulics) the heat sensor comes on indicating that the hydraulic oil is heating (and it is; it gets so hot you can't stand to touch the reservoir for more than a second). I've cleaned the oil cooler, changed the oil and filters but it hasn't improved. I've been told that it could be a restriction somewhere in the system, a bypass valve that is sticking open, and that it could be a weak spot in the tractor. I intend to run it as long as I can. If anyone has had any similar experience with this problem I would appreciate some information on the causes and future problems I might expect (i.e. loss of hydraulic power and cost/time/difficulty of repair).
Kevin
02-15-1999 17:38:31
 Re: White 2-85 hydraulics overheating in reply to Dexter, 02-11-1999 17:40:04
have your Compensator valve checked out by someone with expiriance. If this valve sticks you might notice low engine power also it will kill your pump if not repaired. A relief valve problem will cause heat but you would also be low on hyd. power.
Kevin in ohio
02-15-1999 17:29:33
does your engine seem to be low on power. There is a valve mounted on you're pump that regulates the volume of oil the pump puts out depending on need. If this valve sticks oil over heats,it uses horse power and will kill your pump. This is not the releif valve. Also does you're system work if the releif is the problem you should be having other problems like low hyd. power. my guess is the problem is in the compensator valve mounted on the pump. this must be repaired by someone with experiance. or you will have more trouble.
Wrenchbender
02-15-1999 15:35:42
The hyd. relief valve is letting oil bypass and causing the heat. This is common on White and Oliver tractors with this hyd. system. The relief valve needs to be shimmed up to raise the pressure This is normal wear but should be fixed before the hyd. pump is damaged.
Tom in Maine
02-14-1999 05:18:02
There are usually two reasons for hyd. system over heating; first is cooling system circulating pump is not working,or second is one of the hyd. presure reg. valves is being held open a little creating oil blow- by which will heat up the hyd. system very quick. Hope this will help. Tom in Maine
