REPLACE that damn canister hydraulic filter on your closed center/external pump Oliver/White
Craig A Tull
11-16-2001 11:40:49
I just received my spin on filter set I bought to replace the canister filter on my white 2-105 an was floored when I realized it is a DIRECT bolt up deal!! Now I am going to fit up a 1" valve before the filter so I can change it without dumping all the oil out. Canister filters SUCK!!
Surplus Center
1-800-488-3407
9-4544 suction line filter ( comes with 25 micron element)=27.95
9-4543-25 25 micron filter = 11.95
9-4543-10 10 micron filter, not recomended for suction use = 11.95
9-4544-G suction guage = 7.95 ( money well spent)
I am going to try the 10 micron filter on start-up, I think with the guage I can tell if it's too restrictive, a dash mounted vacuume guage would be a better long term deal.
Craig A Tull
11-17-2001 18:48:35
 Re: REPLACE that damn canister hydraulic filter on your closed center/external pump Oliver/White in reply to Craig A Tull, 11-16-2001 11:40:49
A couple of details have come up, The replacement filter has 1-1/4 pipe threads, the original has a 1-5/8 O.R.B.( SAE 20? ) threads. these are the same only the pipe threads are tapered so the fitting gets tight before the o-ring flushes up with the housing, no problem, thread sealer and your in busness. # 2 is the by-pass in the replacement housing is not as high quality as the original. I was informed that the later models there was no by-pass valve ( I guess they figured it out) so its no problem for me as I am going to disable mine. I would think some consideration would have to be given to, A. what is the min. start-up temp. you would have, See thats the big kicker, If you have the lift raised when you shut down for example and it bleeds down and it's real cold when you crank up the pump will pull hard on the filter trying to raise the lift and open the by-pass. ( I live in S, TX so that's not a big problem for me). and B. A dash mounted vacuum guage or a switch/light would be needed to inform the operator when the filter is starting to get pluged. Starving the pump for oil would not be a good idea I'm sure. I think a by-pass on a system this sensitive to trash is a bad idea, but I guess the guys in the white uniforms at the factory felt it was better to let some trash go by than to starve the pump if the operator did not maintain the systen properly.
Craig
Wrenchbender
11-19-2001 10:06:05
 Re: Re: REPLACE that damn canister hydraulic filter on your closed center/external pump Oliver/White in reply to Craig A Tull, 11-17-2001 18:48:35
Craig, that bypass in the filter should have nothing to do with the hitch or other hyd functions during cold start up. The unloader valve is responsible for destroking the pump at start up. You must be thinking of that "other green" that the hitch drops down on and you have to work the steering wheel while cranking to get it to start cold.:). WB.
Craig A Tull
11-16-2001 11:52:49
The filters supplied were ZINGA SE-10 and SE-25
The SE-10 (10 micron) = HASTINGS HF-738
The SE-25 (25 micron) = HASTINGS LF-430
Craig
Larry from Maryland
11-16-2001 14:26:50
 Re: Re: REPLACE that damn canister hydraulic filter on your closed center/external pump Oliver/White in reply to Craig A Tull, 11-16-2001 11:52:49
My book says there is a bypass on the filter to let oil past if it gets clogged.I dont see it anywhere, but seems like that would defeet the filter.Maybe thats why I get so much metal into the pump.Tell us how your new one works out.
Craig A Tull
11-16-2001 15:07:41
 Re: Re: Re: REPLACE that damn canister hydraulic filter on your closed center/external pump Oliver/White in reply to Larry from Maryland, 11-16-2001 14:26:50
It has the same type by-pass as yours does. Its directly between the input and output fitting. It has a plate over the by-pass port held by a rod and spring, the spring and the position of the clips on the grooves on the rod set the by-pass pressure. The replacement one is set at 5 LB. If I remember correctly that is about 10 inched of vacume and thats allot, Although I am thinking of jacking it up some and or least check its fit/seal. By using a guage you can tell how much vacume is on the pump suction port. I do not like the canister type for many reasons but mostly because you can not be sure the cartridge is sealing correctly, I have cut up some spin on filters and there is no question in my mind that the seal is absolute!
Craig
