Hey shep...
Ryan
11-13-2001 06:13:09
Hate to tear you away from your restore, but you got the bug going for me to finally paint my 1650, could you share the paint codes for the meadow green and clover white, I looked in the archives, but only found Fleetline codes. I also have a cab, was wondering how much paint you figured for tractor + cab. my cab is green with a white top. thanx again for the inspiration and help.
Ryan
Ryan
11-13-2001 20:17:02
 Re: Hey shep... in reply to Ryan, 11-13-2001 06:13:09
Thanks, but I am also looking for amounts, and the code if Shep has it handy, as I probably will not get it at an agco dealer, A good friend is a paint rep, just wanted to give him some numbers and amounts and have him get it.
Shep
11-14-2001 19:43:34
 Re: Re: Hey shep... in reply to Ryan, 11-13-2001 20:17:02
Yeah, I get my paint at the Agco dealer, I will look on the can and get you the paint codes when I go to the shop tomorrow. I just finished painting my 1855, it has a full white cab, and I think I used about a gallon and a half of meadow green and about 3 quarts of white, but I put paint on kinda heavy and that was about two coats. I was thinning the paint at a 1 to 4 ratio. I also went through two gallons of primer on the entire tractor.
I will follow you up with some paint codes tomorrow.
Ryan
11-15-2001 05:55:37
 Re: Re: Re: Hey shep... in reply to Shep, 11-14-2001 19:43:34
Thanks Shep, that is just the info I need to get the ball rolling.
Shep
11-15-2001 14:46:08
 Re: Re: Re: Re: Hey shep... in reply to Ryan, 11-15-2001 05:55:37
Ok, I forgot to mention that I did not paint the cab on that tractor this last time, so the three quarts of white is what it took to paint the white on the tractor and not the cab, so figure a little more for the cab.
The paint numbers I found were Meadow Green 79014804 Clover White 79014806
I think those are the Agco numbers, I dont have any other numbers for the paint, like I said I get it off the shelf at the Agco dealer. Maybe they can cross reference that.
Hope that helps some
Ryan
11-15-2001 20:34:30
 Re: Re: Re: Re: Re: Hey shep... in reply to Shep, 11-15-2001 14:46:08
Thanks alot, shep.
Ryan
JDP
11-13-2001 18:54:37
Shep told me that he gets his paint from AGCO, if I remember right.
