HG/OC 3 question
John
11-10-2001 21:10:47
Help! Going to look at an HG (or OC 3?) tomorrow. Cute little crawler but I don't know much about them. Would appreciate any information on what range of prices these machines usually bring. I understand this one needs a front wheel bearing but has a very good engine. It also has a front blade. The more opinions the better! Thanks
John
11-11-2001 22:42:38
 Re: HG/OC 3 question in reply to John, 11-10-2001 21:10:47
Well, I went ahead and bought the HG42 this afternoon--and one side frame was broken and poorly weld repaired. Any idea how these are fixed properly? It does have a nice 7' Holt blade on it. How can I find out what serial number 54GA228 signifies?
Canada Grant
11-12-2001 14:20:16
 Re: Re: HG/OC 3 question in reply to John, 11-11-2001 22:42:38
Wedals Oliver book says 1951. I have seen frame repaired by welding on piece of round bar bent to shape ontop of rail . I plan on taking my engine out then weld inside and out then add rod on top.
John
11-12-2001 18:56:32
 Re: Re: Re: HG/OC 3 question in reply to Canada Grant, 11-12-2001 14:20:16
Somebody did a rather poor repair on this frame. They (poorly) welded the frame to the side of the engine casting (or clutch housing), and there are no bolts through to the engine. I suppose they're stripped or other bad news. Thanks for the suggestion and info. Any idea where I might find a good gas tank for this HG?
John
11-12-2001 18:55:39
Canada Grant
11-11-2001 18:55:44
Watch for frame breakage on them just at rear of engine where it attaches onto bellhouse . There is a cut out of the top if the frame rail and if worked hard they break here . Also look at where frame rail is attached to the trany as there was updates that strenghtened that point also. Good luck
