Should I Buy? (Oliver Row Crop 60)
D. Stewart
11-08-2001 17:18:12
I attended my first antique tractor pull a short time ago and had a blast. So much that I am planning on getting into this myself. I just found an Oliver Row Crop 60 (I was quite impressed with the Olivers)and as I didn't want to "jump" into anything I thought I'd ask for a little input as to whether this tractor sounds like a good buy. The tractor is all there with the exception of the side curtains. Hood & grill both are in very good shape. RUNS GREAT !! Transmission, clutch and brakes appear to be fine. P.T.O. and "lift" box also work fine. Tires are "OK". Problems I noticed are: Spring set-up for the seat is a little "funky". Needs a steering wheel. Rear fenders aren't too bad but need a little bit of work. Front "nose" casting has been welded to the frame using about a 3" x 6" long stiffener plate on the outside on both sides (bolts are still there and look to be intact and it doesn't appear as if anything is cracked). This problem bothers me the most but it does appear as if maybe the front kept coming loose and somebody just welded it to keep it in place. Radiator looks a tad leaky. I was told by the salesman (local tractor dealer has it) that it is a 1950 model year which he says he got from the serial # but everything I read says that the 60 was last made in '48? And lastly I noticed that the engine has a spin on oil filter which I thought was kind of odd for something of that vintage. Asking price for the tractor is $1,400.00. All in all the tractor appears to be fairly sound. Is this a good buy? Any input would be greatly appreciated. Thanks, D. Stewart.
Scott Green
11-09-2001 08:41:11
 Re: Should I Buy? (Oliver Row Crop 60) in reply to D. Stewart, 11-08-2001 17:18:12
The Oliver "60" does have a spin on oil filter.They quit making them before 1950. 1945 and up had the nicer transmission and shifting lever. The price sounds fair if the tractor is in good shape. A touch on the high side(a little more fair to the salesman). I know where one can be bought for $800.00 near Dansville , New York. It is a 1941 model. I paid $1,000.00 two years ago for the one I have , which is in very good shape. It is a 1945 model. Nice little tractor. Most pullers prefer the model "66" over the "60" for tractor pulling. The "60" does not have live PTO or hydraulics.
D. Stewart
11-09-2001 13:06:35
 Re: Re: Should I Buy? (Oliver Row Crop 60) in reply to Scott Green, 11-09-2001 08:41:11
Thanks for your reply Scott. I am a bit confused now. The tractor in question does have both a rear and a side (for belt pulley I assume) PTO shaft. It does not have any hydraulics but it does have a mechanical lift unit which is operated with a foot pedal. It also has the #60 cast in the front with what appears to be the correct grill assembly for a RC 60. Could this tractor be a "hodge podge" put together thing or what ? I guess I need to check the serial #'s. Thanks for the info about the oil filter as that has answered one of my questions.
Later, D. Stewart.
gary m
11-09-2001 15:23:22
 Re: Re: Re: Should I Buy? (Oliver Row Crop 60) in reply to D. Stewart, 11-09-2001 13:06:35
there are much better deals around. Dont jump at the first one you see. also get a Super or newer if you want to pull or use it for anything other then just utility. ground PTO sucks. need hydraulics for anything more modern then a baler.
roy mi
11-11-2001 06:33:51
 Re: Re: Re: Re: Should I Buy? (Oliver Row Crop 60) in reply to gary m, 11-09-2001 15:23:22
I live in mi i can by a 66 or77 for 1000 and thay are in good shape. and thay run good.
