Oliver plow help
Eric
11-07-2001 12:14:11
I picked up an Oliver plow at an auction and want to know the type.Its a 12"/2 bottom on steel,if looking from the hitch end it has a ratchet lever on the right hand side an a crank adjuster on the left hand side. The coulters have what looks like small bottoms attached to them. I'm going to restore it and would like to know what colors it was painted and if there are manuals available? All help useful. Thanks.
Eric
Jeff
11-09-2001 23:00:10
 Re: Oliver plow help in reply to Eric, 11-07-2001 12:14:11
Eric, does the plow have a clutch lift, hydraulic lift, or a rooster comb lift? Look for part numbers starting with "EP" on any of the parts on the plow. They will be cast into the piece and should be easy to see. If it does have some, it is definitely an Oliver plow.
Paul Stanley
11-07-2001 21:33:12
Is there a model number cast into it?
John Nesklada
12-22-2006 15:39:32
 Re: Re: Oliver plow help in reply to Paul Stanley, 11-07-2001 21:33:12
Paul, ran across these old discussions regarding an Oliver plow which sounds similar to the one I acquired. Mine has the #EP295X stamped on the frame. Looking for colors and info. Thanks, John
Paul Stanley
11-07-2001 21:33:10
