Need Input on Buying Cockshutt 40(30)?
TMAC
11-04-2001 18:59:05
I have Case,Farmall, and Fordson tractors and this will be my first other brand tractor. Sheetmetal is good and it was driven into a shed a long time ago. If it will run well I will pay $800 for it. My main question; is there 3pt conversions for it? The tractor has a engine driven pump and I would like to work it around the house but not do anything to it unreversable to original.
Ralph
11-07-2001 21:46:57
 Re: Need Input on Buying Cockshutt 40(30)? in reply to TMAC, 11-04-2001 18:59:05
Yes the 30 and 40 were available with three point hitch. I have the parts book and advertising brochures for the 40 showing detailed drawings of the hitch. I have never seen a factory 3 point hitch though so they were rare in this area of Canada anyway. I built my own out of scrap parts plus the lift links and draft arms from a Fordson Major. Works great on a 6 foot snowblower.
Al
11-05-2001 17:46:18
I built a 3pt for my 30.It mounts the same as the factory option with no mods to the tractor.You need the optional seat(I think its called a knofler) because the rockshaft is activated by a cylinder under the seat.(You could probably offset the cylinder to one side for a standard seat,just would not look as stock).The rest is straight forward fabrication,but a welder& drill press will be needed,and a small amount of lathe work on the rockshaft and it's bearing points.Other than that it's just angle iron,chain,flat stock,round stock, bolts and weld on replacment ends.
lots'a luck
Al
p.s.other than the hydrolics,materials were under $50cdn,thats about a buck 95 us
Unimog
11-05-2001 10:18:37
There is a company in Aberdeen, SK Canada that is
suppose to make 3-points for the model 30. The
numbers I have are 1-800-383-2228, 306-253-4343
and Fax is 306-253-7146, ask for Joe. I don't
have any first hand info but supposed to be a 4
bolt installation, weight #300 and CAT I and II.
May not be original looking but at least it adds
to the function of the tractor.
Unimog
Mike M (WA)
11-05-2001 08:32:16
The "roundnose" Cockshutts had optional 3 point available from the factory. The problem is, a lot of the "big prairie" farmers had no use for 3 point, so ordered the tractors without. Result is that the 3 point parts are in demand by collectors to retrofit their tractors. I have the 3 point on my 35, and it works great. You'll like the tractor- live hydraulics, 3 point and independent PTO in the '40's, when most of the other mfgrs were still making "iron horses" to just pull stuff around (and a nifty rope to pull when you want to raise the implement). As far as I know, nobody makes an aftermarket 3 point kit for these- not enough of them around.
