Gas tractor always sputters
Rick
10-30-2001 08:45:18
have 1755 and 770 gas tractors. I can't get them to run correctly know. Both just act like not getting fuel. I have rebuilt carbs cleaned lines.I am using gasohol could this be the problem. I use it in everything else no problems. I am at a dead end on this problem. Why does the manifold always frost over just above where carb mounts.
Jake
11-01-2001 05:53:23
 Re: gas tractor always sputters in reply to Rick, 10-30-2001 08:45:18
The frosting at the carb is caused by the venturi effect[air entering a vacum through a smaller opening. Whe you rebuilt the carbs did you replace the brass venturi tube in the original position?. If reversed it changes the air flow trough the carb. the smaller end should be at main jet to vaporize the fuel properly. Worth a look and good luck.
kmcmillan
10-31-2001 10:27:29
Rick, the frosty intake is caused by the evaporation of the alcohal in the fuel. Alcohal get cold as it evaporates. When you speeed up the evaporating process it further decreases the temp of the gasohal vapor. As for the sputtering problem, it could be caused be oxygenated fuel.
the newer fuel formuals have oxygen added to help lower exhaust emissions. More oxygen means your getting less fuel into the intake. Try adjusting the carb. If that does nat work, try 1 quart of marvel mystery oil in each 10 gallons of fuel. that sure made a difference in my 770. Let me know how it goes. Kraig
