Super 88 or 77? How to tell?
D13
10-25-2001 13:52:23
Spotted a 6 cylinder, wide front, dual hydraulic, PTO equipped Oliver. The tag is on the dash, which would make it a Super. It reads 21 482 - 706 for a serial, the spec number is wiped out.
From what I can tell, the first digit of the last 3 combo indicates the series. In this case, it's a 7, meaning this is a Super 77.
Any other reasonable way to distinguish S77 from S88? Given the conditon and/or lack of sheet metal this could be either....
Brian
11-02-2001 18:29:14
 Re: Super 88 or 77? How to tell? in reply to D13, 10-25-2001 13:52:23
the 77 block is about 28.5" long and the 88 block is about 1 to 1.5 inches longer
Dkaiser
10-25-2001 15:30:30
Try checking the block for a casting number. I think the supers still used the old sysem where a letter preceeds a number on the casting number. If it's a 77 it should say something like M100 and an 88 would be K100. That would at least tell you what the engine is if they still used that system.
