Super 55 leak
PHIL R
10-24-2001 16:29:12
My super 55 gas all of a sudden has a leak that I believe is transmission fluid. It apears it's comming from right behind the oil pan. I think the dust cover for the fly wheel has fallen off at the same time the leak started,and its comming out of this opening. Anyone have an idea what's causing this leak?
Paul Stanley
10-24-2001 22:44:19
 Re: Super 55 leak in reply to PHIL R, 10-24-2001 16:29:12
here is a link on instructions for splitting a Super 55 or 550. Go to album 26.
Jake
10-24-2001 22:16:37
If the oil comes from front of the fly wheel could indicate rear main seal, if from the rear would indicate from the trans probably the PTO seal which is the lowest section. The hydraulic lift has a sealed pan with no route to the clutch and PTO section. No easy fix.
Shadetree
10-24-2001 22:05:23
Your leak can very likely be transmission oil leak. Inside that area that you see your flywheel also houses the pto clutch pack as well as your transimission input shaft, the bottom shaft coming into that area is the pto clutch drive shaft and the front seal is probably leaking and draining out just under the flywheel. The tractor will have to be split to repair that problem but it an easy tractor to split and reassemble. Good Luck Shadetree
