Shifting gears on a 1650 Oliver
Verlyn Schmidt
10-22-2001 15:31:51
I recently purchased a 1650 and really like it. However lately it has been very difficult to shift. I've checked the transmission fluid and the clutch seems ok. Any suggestions??
Don
10-25-2001 09:07:22
 Re: Shifting gears on a 1650 Oliver in reply to Verlyn Schmidt, 10-22-2001 15:31:51
I have a 1755w/a loader and a 1600. the 1600 shifts pretty easy, but on the 1755 I have to work the clutch some times. when we first bought it it was almost impossible to shift, but now through time and experience i usually have no problem shifting it.
Shadetree
10-23-2001 22:37:25
In my experiences in repairing the Oliver Tractor I have found that through wear and tear that the clutch pressure plate linkage will sometimes wear unevenly and will cause the pressure plate to release unevenly. This in turn will not fully release the clucth plate from between the flywheel and the pressure plate causing the input shaft to turn and making it very difficult to shift into gear and yet shift out of gear until this condition is allowed to get very severe. This can be proven very easily, just remove the inspection cover on the side of the bell housing just behind the engine, it is held in place by three pan head screws. Using a flashlight look in at the fingers of the clucth and very slowly pull down on the clutch pedal or have somebody help you by pulling it down slowly and watching to see if the throw out bearing touches both fingers at the same time. Then you need to roll the engine over until you see the next finger and repeat this same procedure, I beleive that on the 1650s there are only 3 fingers to most of the clutches for this tractor some may have 4. When the clutch is adjusted properly your shifting will improve a lot. Good Luck Shadetree
Bob Semrau
10-23-2001 05:56:45
I've found that my 1600 goes into gear a lot easier if the hydra-power is in low (pulled out).
Larry from Maryland
10-22-2001 15:42:12
Well I would like more info. Do you have a 2or3 speed powershift? Is it shifting slow or hanging in direct drive? Are all the gears shifting hard or just a few?
Verlyn Schmidt
10-22-2001 16:08:34
 Re: Re: Shifting gears on a 1650 Oliver in reply to Larry from Maryland, 10-22-2001 15:42:12
Larry I have a hard time getting the tractor in gear. Once it's in gear it will go from direct drive to over or under with no problem.
Larry
10-23-2001 16:07:01
 Re: Re: Re: Shifting gears on a 1650 Oliver in reply to Verlyn Schmidt, 10-22-2001 16:08:34
You should use low to put it in gear.The clutches in the 3 speed tend to hold the input shaft from turning.olivers mostly have shiftcoller constant mech trans.If the collers don't line up they don't go in easly.There is no sinkrowmesch to help you,so working the clutch some helps,and when you change gears shift right before it comes to a complete stop.I have 2 1650s and the one without a 2 speed shiftd soo much better.Once you get used to it,shifting not so hard .The 1550 is evan worse.
Ed
10-23-2001 06:46:28
The Oliver's I have driven have all shifted hard, I guess it's an Oliver thing. An 1855 when I was young and the tractor new, 1800, and 770.
Banging the shift out of and into gear was a not uncommon. I generally worked the clutch and tried not to shift on inclines or under load.
I remember seeing the owners of the 1855 rock the tractor to get it out of gear and start it up. They even jacked up a tire. The tractor was parked on the front of a bump in the yard in gear with the brake on. I guess it had a safty switch preventing it from starting because as soon as they were able to release the brake and put it in netrual it started right up.
