Smokes Under Load
HoyBoy
10-20-2001 12:25:42
I've been looking at a 550. The dealer was doing some work on it to smooth it out at idle. It was speeding up and slowing down 800 or so rpm and sometimes just dying out at idle. They tested the compression - results - 150# on each cylinder.
When they tested it on the dynamometer (several times) it smoked a lot and they could get only 28 HP out of it. With that compression, what could be making it so powerless & smoke so much? The dealer dropped his price by $700 but I'm not sure what it would take to get the tractor up to snuff. Any theories?
Larry from Maryland
10-20-2001 15:58:59
 Re: Smokes Under Load in reply to HoyBoy, 10-20-2001 12:25:42
Is it gas or diesel.
HoyBoy
10-21-2001 04:04:44
 Re: Re: Smokes Under Load in reply to Larry from Maryland, 10-20-2001 15:58:59
When I saw it run, the smoke looked more black right at the back of the tractor but as the smoke drifted up in the air it looked more blue like oil smoke. I didn't witness the large amounts of smoke that the dealer told about when they tested it on the dynamometer.
Adonis
10-20-2001 18:24:27
What color is the smoke? black? or blue?
HoyBoy
10-20-2001 16:28:57
Gas
HoyBoy
10-20-2001 16:27:02
Gas
Larry from Maryland
10-21-2001 05:08:04
 Re: Re: Re: Smokes Under Load in reply to HoyBoy, 10-20-2001 16:27:02
I would suspect the manifold gaskets where bad alowing some of the exasht to get back into the intakes.Tractors will run,sound a little rough,and get worse as more heat and more load is added.Its hard to get them to idle or adjust carb's.Depending which of the seals has fallen out makes a big differance how they sound.This is a very common problem with these tractors as a bad set of gaskets were used during assembly.If a tractor has been overhauled and new exasht and intake gaskets installed you don't see this problem.The tractor might need new rings too,my guess is manifold gaskets will fix well enough to use it did mine 20 years ago.
kevin the super 55 owner
10-20-2001 19:09:07
When my Super 55 was having the very same problems, it turned out to be mostly points. the gap was a tad too wide. I also converted to 12v and she runs like a champ now.
Don
10-25-2001 09:49:31
 Re: Re: Re: Re: Smokes Under Load in reply to kevin the super 55 owner, 10-20-2001 19:09:07
Also check the plugs. sometimes it's just a very simple fix that nobody thinks about
