How do you check a voltage regulator?
JW(NC)
10-18-2001 18:52:58
I have a voltage regulator that is not mounted off my Oliver 440. It is not running at the present time. How do I check this regulator to see if it is good, or needs replacing. It was mounted on top of the generator. This tractor is 6 volt. I have another regulator that came off a Farmall that I might be able to use, but I also need to check it. I do not know what voltage it is used on. Is there a way to tell what voltage the regulator is for or does it make a difference?
Sorry if I am confusing. Electrically challanged!
Larry
10-19-2001 15:56:30
 Re: How do you check a voltage regulator? in reply to JW(NC), 10-18-2001 18:52:58
We used to have the repair places check them,and adjust too.Most of the old farmalls were 6 volt too.
Dan
10-22-2001 22:00:08
 Re: Re: How do you check a voltage regulator? in reply to Larry, 10-19-2001 15:56:30
Take the voltage reg to an alt/starter rebuilder , they will have testers just for that .
Regulators are matched to the gen ,so one from to another tractor may not work on yours . I am a rebuilder , -if you have model numbers or part numbers on these reg,s let me know and I will look them up .
