Oliver77 gas or diesel for pulling
newbie
10-16-2001 18:30:37
I am intrested in getting a oliver 77 to pull in the 4000# and 4500# class in the "stock" (meaning it suppose to be a stock tractor, but winnners are not quite stock!) i was wondering what tractor is better for pulling. I am aware that the diesel pumps are expensive to rebuild. is there two diffrent manufactures of the pump? if so which is the better brand. i would modify this 77 very lightly. can i get a 77 gas and make the motor into a super 77? Any sugestions would be appreciated!
thanks in advance!!
don
10-16-2001 19:34:41
 Re: oliver77 gas or diesel for pulling in reply to newbie , 10-16-2001 18:30:37
you can make ether a gas or diesal to a super77 size moter.you can go to 1550 sleeves and pistons in ether.the gas can go to 3 3/4 bore safely.the gas will make more power cheaper.weight wise they are about the same.
