RE: Oliver 770 clutch/transmission help
Fred Miller
02-05-1999 19:44:44
I'm still dealing with that clutch/transmission problem I've been having. After some very fine tuning of the pressure plate fingers my problem of dragging gears only exists if I try to put the tractor in gear from nuetral without waiting 10 seconds. Does anyone know if there is a tension adjustment on the gears that would be spinning when the tractor is in nuetral with the clutch pedal out? Thank you.
Shadetree
02-06-1999 07:34:52
 Re: RE: Oliver 770 clutch/transmission help in reply to Fred Miller, 02-05-1999 19:44:44
Fred The transmission should have 80\90 Wt. transmission oil first. The heavy oil helps slow the gears when you step on the clutch. The transmission input shaft should I beleive have about 3 to 5 Inch pounds of preload above seal drag. However I don't beleive getting that preload will help you slow the shaft enough to help your clutch problem. These tractors do have to be idled down to shift them into gear from neutral, That is very normal to have to wait a couple of seconds from an idle to get it into gear. I have had some button type clutches give the same problems you are having but they have a diffrent soulution. The large rivets they use create a suction to the flywheel or the pressure plate and have to have a small groove cut from the edge of the rivet to the outside edge of each pad to releave this problem. But I beleive your tractor should have the fiber disc clutch and will not have this problem at all. I have heard of some tractors that have had the bell crank (the part that pivots for the linkage just above the transmission input shaft.)turned upside down giving the linkage to short of a pull on the clutch linkage. I hope this is a little bit of help to you. Good Luck Shadetree.
Wrenchbender
02-15-1999 15:04:47
 Re: Re: RE: Oliver 770 clutch/transmission help in reply to Shadetree, 02-06-1999 07:34:52
Fred,Shadetree brought up a good point,I know on the newer Olivers the clutch fork can be put in backwards.I haven't worked on many 770's so I'm not positive that is the problem.On those newer ones the bolt that clamps the fork to the shaft is coming in from the backside when the fork is in the proper place. You have to turn the fork up to get the bolt in.If you haven't replaced the pilot bearing or bushing it could be dragging causing the clutch shaft to turn.just a couple things to look at. Good Luck!
Wrenchbender
02-15-1999 15:04:41
