What kind of fuel filter does 88 diesel use?
Hank
10-14-2001 16:36:38
I have a 1952 88 Oliver diesel.It has a cartridge type fuel filter on the right side (it looks factory but I have not checked other 88'S )It has FRAM on the top steel part of the cartridge there is a number on the inside of the same piece #101482.I do have the paper filter but the # is gone It measures about 2 3/4 inch in dia. by 2 3/4inch high.Can someone tell me if this is factory and give me a FRAM # or other brand of filter that will fit. THANKS
oliwfedlr
10-19-2001 18:44:19
 Re: What kind of fuel filter does 88 diesel use? in reply to Hank, 10-14-2001 16:36:38
the filter you have is origional the oliver part number is 103096as it is the same filter used on the hyd.
John P.
10-15-2001 17:07:10
Hi, I have an older AC-DELCO farm catalog and here is what it lists for the Pre 1957 Model 88D Oliver Tractor:
Lube: P411
Fuel: TP526
Fin. Fuel: TP573
Hydraulic: TP526
Hope this helps.
