Find a crank
Justin
10-10-2001 12:45:09
I need a 3 main crankshaft for a Cockshutt 30. Where? How much? Guaranteed usable!?
Al
10-14-2001 05:45:15
 Re: Find a crank in reply to Justin, 10-10-2001 12:45:09
I have a standard 3 main that could be ground .010 under and used for 50 more years.I'm in eastern ontario,post if interested.
Al
Justin Lupkes
10-15-2001 10:43:32
 Re: Re: Find a crank in reply to Al, 10-14-2001 05:45:15
Al Thanks for the info. Money is tight and I,m scared of the shipping. How much for the crank and shipping to Brainard, MN? Do we need to match forging numbers? Please check.
Al
10-16-2001 03:39:41
 Re: Re: Re: Find a crank in reply to Justin Lupkes, 10-15-2001 10:43:32
$50 in my pocket would be fine,don't know about shipping,will check# tonight&post.
Al
P.s.took out of a runner last fall because I needed the block,I'm not a dealer.
Jake
10-18-2001 02:30:26
 Re: Re: Re: Re: Find a crank in reply to Al, 10-16-2001 03:39:41
At 50 bucks I'll buy it and make an end table for the living room[paint it Oliver green w/yellow trim]
Al
10-18-2001 03:32:34
 Re: Re: Re: Re: Re: Find a crank in reply to Jake, 10-18-2001 02:30:26
Don't get much for 50 bucks,but red,not green&yellow!
Al
10-16-2001 04:00:32
Just a thought,do you know anyone in upstate NY that could meet me near the border,say Watertown?
Al
Justin
10-16-2001 11:02:10
 Re: Re: Re: Re: Re: Find a crank in reply to Al, 10-16-2001 04:00:32
Al, I know someone near Syracuse but shipping would be better and more timely. Please check on shipping to Brainerd, MN. $50 sounds fine if you'll let me have it checked out first. Thanks. Jud
Al
10-16-2001 14:13:28
 Re: Re: Re: Re: Re: Re: Find a crank in reply to Justin, 10-16-2001 11:02:10
Hi
Casting has atlas 5 and b-3200.How do you propose you check it out before you buy?
Al
Justin
10-17-2001 07:46:51
 Re: Re: Re: Re: Re: Re: Re: Find a crank in reply to Al, 10-16-2001 14:13:28
HI please explain casting has atlas 5 and b-3200. Justin
PS.. Are you a member of the Cockshutt Club?
Al
10-17-2001 09:09:53
 Re: Re: Re: Re: Re: Re: Re: Re: Find a crank in reply to Justin, 10-17-2001 07:46:51
The above# are cast into te crank.No,I am not a club member,shipping will cost more than the crank,might be wise to find one closer to home.
Al
Al
10-17-2001 09:08:43
Al
troy
10-10-2001 17:22:51
www.budaengine.com
Canada Grant
10-11-2001 05:27:00
 Re: Re: Find a crank in reply to troy, 10-10-2001 17:22:51
Try Steve Radford at Ontario Used Tractor Parts 519-523-4922. Has used cranks in stock and can get bearings also if required. Ships UPS .Specializes in older tractors .
