Oliver 770 tractor
Alan
10-10-2001 10:18:21
I am working on fuel gauge-water temp-gauge combo. I have installed new unit bought from Agco Neither will work I have replaced senders also. The tractor is now negitive ground with alternator It worked before gauges went bad on positive ground like it came out factory. I was wondering if anyone has ran into this before I could really use some help Thanks for the time. Alan
Larry
10-10-2001 16:31:21
 Re: Oliver 770 tractor in reply to Alan, 10-10-2001 10:18:21
yES CHANGEing the ground will make a differance.If you have a 2 wire guage you can switch the wires,it might work.On the ones I did(2oliver 1600)I got all the guages working.The idit lights were not so good.
