Tyro question
rwh
09-30-2001 18:33:16
Just bought a 550 gas and was quite happily mowing with a 6' Befco when tractor stalled out with exactly the sound of running out of gas. Checked tank; plenty in there. Started it right up and drove another 50 yards or so and same story. Decided maybe it was overheated, so took to the shed with no further incident. I would think maybe vapor lock, except it fired right up. Any ideas?
Paul Stanley
09-30-2001 20:35:05
 Re: tyro question in reply to rwh, 09-30-2001 18:33:16
Next time it happens try opening the filler cap and see if it makes a difference. Also, if you have a bad coil, they will fail when the engine gets hot. Mike might have the answer too.
Mike M (WA)
09-30-2001 19:50:53
Sounds like its starving for gas, probably due to accumulation of crud in the gas tank outlet. Turn off the fuel valve and remove the sediment bulb and empty it, then put it back on and see how fast (or slow) it fills. If it takes more than about 2 seconds to fill, you're probably plugged. Empty the fuel tank, unscrew the sediment bulb fixture from the tank, and poke a wire up through to free up the worst of it. You'll probably have to remove the tank to really clean it.
