What's this lever do?
Gary Hoyer
09-29-2001 04:04:22
I'm looking at a 1962 (or thereabouts) 550. There is a lever near the right front corner of the seat. The lever is about 8" long. The lever appears to control a Vickers valve. I asked the salesman & one of the mechanics what it was for
and neither one could tell me for sure. This tractor did not have any hydraulics hook ups anywhere but I noticed that the valve that this lever controlled had what looked like pipe plugs perhaps intended for hydraulics connections?
Mike M (WA)
09-29-2001 07:40:27
 Re: What's this lever do? in reply to Gary Hoyer, 09-29-2001 04:04:22
The lever controls the Vickers remote hydraulic valve. It's a rare and sought after option. The two pipe plugs on the bottom of the valve are for the hoses to the remote connectors on the back. The pointer on the top of the valve adjusts the flow volume. Try the valve to see if it's stuck- they tend to sieze up if not used, since most older tractors have water in the hydraulic and transmission fluid. The valve is very easy to remove and service, however.
John P.
09-29-2001 06:31:02
The only Oliver factory levers that should be there are the ones for the 3 point hitch (if equipped) and the one for an external control valve (also if equipped).
