You bet its supercharged. By deffinition any mechanical means of gathering and force feeding air to an engine besides piston movement is supercharging. The person below who said the supercharger was belt driven on the Detroit (GM) engines is wrong. They are driven off the accessory drive. When these "blowers" are adapted to gas engines they are usually belt driven althogh many years ago they were also positioned in tront of the engine and hooked directly to tht crank. There are currently 5 types of superchargers. All superchargers are a form of one of the basic 5 types. 1) Roots type. These are what originally came out on the GM Detroit Diesel engines and made famous later by the Fuel (Nitro Methane) guys in the 60's. These are what dominate NHRA alcohol and nitro classes and are also widely used in monster trucks and tractor pulling. A variation of the roots blower is the screw type suprcharger like the PSI. 2) Centrifugal. These are best known from the Turbocharger which uses the remaining energy in exhaust gasses to drive a turbine wheel which is connected to a compressor wheel. The great advantage to the turbo is that it is non parasitic (draws no horsepower from the engine to drive it) and by being able to freewheel at speeds over 100,000 rpm it can have an exponential output. Another type of centrifugal super charger is the Paxton Mc Cullough which is a compressor wheel belt driven from the crank and geared up to great speed. These PMcC's were made famous by the 57 T'birds that Ford factory installed PMcC's on a few 312's. 3)Vane. These were basically drums with slots containing sliding vanes and placed in an eccentric. They were only used in low hp applications and suffered from a dire case of heat build up. 4)Axial Flow. Strange one. Basically the compressor section of a jet engine that is belt driven off the crank. Very rare, expensive, and difficult to adapt to an engine. But they say the sound alone is worth all the trouble and expense. 5) Comprex Pressure Wave Supercharger. Developed in the 70's by Brown & Boveri in Europe for use on diesel engines. Uses pulses from the exhaust to directly push air to the cylinders. Although it is belt driven it is basically non parasitic as the belt is used only to keep the unit in time with the engine. The output is close to being on par with a turbo but actually has a little more bottom end torque but gives up a little on the top end. The unit isn't widely used because of its cost and difficulty to plumb correctly to the enigine. The placement is difficult because of the need to have a short direct path for the passage of air from the unit to the intake.
