Oliver 550 Diesel Oil Level Going UP???
Eric
09-26-2001 09:04:53
My 550's oil level seems to be going up and up. How can I tell whether the problem is coolant or blow-by? Has anyone else ever had similar problems? The oil is pretty black and it takes around 50 hours of operation to get the oil about an inch and a half over the high mark on the dipstick.
Thanks!
Larry
09-26-2001 09:49:21
 Re: Oliver 550 Diesel Oil Level Going UP??? in reply to Eric, 09-26-2001 09:04:53
The oil will turn grey if it is water.It seems like a slow leak to me.Could be a bad injector.The best quick test is to remove the energy cells opossite side from the injectors,see if one cylinder is wet.Test or repair that injector or do them all.There are several other causes for oil increases,but they are faster leaks.The fuel pump can be bad,the oring in the injector pump can be bad,a valve can be stuck not letting one cylinder fire.
j.appel
07-24-2006 20:27:25
 Re: Re: Oliver 550 Diesel Oil Level Going UP??? in reply to Larry, 09-26-2001 09:49:21
a slow build up probably a injector leaking,quick
build up=fuel pump diaphram..had a cockshutt 1600
went from full to pouring diesel out dip stick tube over night...thanks jim
