I've successfully fired up a Farmall, a couple Olivers and a Chrysler flathead industrial motor under similar circumstances. Here's what I did: 1 - Drain the oil pan, replace the filter and refill with fresh oil. 2 - Use compressed air to blow off (clean) the head around each spark plug, then remove the plugs. 3 - Dump a couple ounces of engine oil into each cylinder. Leave the plugs out for now. 4 - Hook up a fresh battery and try cranking the motor. If it spins, crank it until oil pressure registers on the gage. This will lube the cylinders and the bottom end. 5 - While cranking, check also for spark from the distributor. If no spark, cleaning and regapping the breaker points usually fixes the problem. 6 - If the gas tank is dirty inside (can virtually guarantee it will be!), clean the tank thoroughly before filling with fresh gas. If the tank is real bad, rig a temporary fuel tank and hose to the carburetor - an old Evinrude "Cruise a Day" tank works great for this. 7 - Replace the plugs, fill the radiator with water, turn on the gas and crank 'er up. If you are lucky you'll be rewarded with a huge cloud of blue smoke and a running motor. Good luck!
