Starting system for oliver 55
DENNIS ARMSTRON
09-20-2001 07:44:36
can any body help i just purchased a super 55 diesel model i dont know if thier is rod missing to the starter to kick the
lever down to engage the starter i do have a manual for this but it really doesnt explain it how the starting engages to the silonold
MN Mike
09-23-2001 16:58:58
 Re: starting system for oliver 55 in reply to DENNIS ARMSTRONG, 09-20-2001 07:44:36
Mine - 1956 S 55 diesel had some sort of kick - rod, but someone fabricates a handle that is attached to the tin on the drivers side (email me for photo) & it works real good. Not stock but OK. Good luck. If you need more info, I can do more pictures.
Pete in Post Falls
09-23-2001 06:33:31
Mine has a straight rod on the lower left side that simply pushes the starter solenoid in. Once when the pin fell out, I used a long screwdriver to push in the solenoid.
Lots a Luck!
Pete in Post Falls
Pete
09-20-2001 17:41:36
Dennis
The S55 diesel had two starting systems
1 - key start with a seloid on top of the starter found on late models
2 - foot pedal starting - which sounds like what you have, where the pressing of the pedal toggles the starter drive first (there is a yoke on the bottom of this hooked to the starter drive) then makes contact with the electrial switch to activate the starter motor only after the drive is engaged.
email me if you have more ? or need some pics
Good luck
pete
Al
10-01-2001 15:22:23
 Re: Re: starting system for oliver 55 in reply to Pete, 09-20-2001 17:41:36
Pete, I've been looking at the starter on my S55 and wondering how the linkage worked as well. Would appreciate a picture emailed to me.
thanxs al d
Jake
09-20-2001 09:28:28
The 55's had 2 different starter activation systems. The 6 volt had a spring pedel on the right side and a rod going across in front of the battery,at tstarter the rod had a toggle pinned to the switch, pushing on the pedel pushed down on the switch. Later 12 volt had key start with a solinoid mounted on the starter wit a wire to the switch. Both have bendix drives. Also 1 6v and 4 12v starters were used on these tractors. Hope this was clear enough and helps.
