Side panels on 77 diesel
Canada Grant
09-20-2001 06:06:01
I looked at a 1953 77 diesel yesterday with a very odd set of side panels. The sides were cut out in the center ,they had two louvers along the top then 5 short louvers at the front . They look to be factory made as there are lips formed on the inside of panels and the ends of the short louvers are formed. Its somewhat like a 70 standard panel with a square hole cut in the side. Could this have been factory fix for the overheating problems before they went to the super style of panel? The motor is stuck but a very straight tractor otherwise and it might follow me home yet !Any ideas on these panels?
Jerry B
09-20-2001 18:23:47
 Re: Side panels on 77 diesel in reply to Canada Grant , 09-20-2001 06:06:01
There should have been a square "cover" over the hole. It looks very much like a square cake pan protruding out from the side curtain. This was to provide clearance for the injection pump if memory serves me correctly.
Canada Grant
09-20-2001 20:03:13
 Re: Re: Side panels on 77 diesel in reply to Jerry B, 09-20-2001 18:23:47
I have a 1952 77 diesel standard restored that has the diesel side panels. These side panel "holes" are almost the full length of the engine on both sides . If my scanner worked I'd post pictures as they are just too well done to not be original and the rest of tractor is very straight original machine.
Paul Stanley
09-21-2001 06:45:11
 Re: Re: Re: Side panels on 77 diesel in reply to Canada Grant, 09-20-2001 20:03:13
If you get the HPOCA newsletter, check out the July/August 2001 issue. There are some pictures on page 14 of a 77 diesel. The article is how to make the side panels from a pair of gas side panels. Nice close up photos.
