Oliver 77 generator wiring help
JOHN
09-18-2001 17:31:36
I have a 1953 oliver 77. Restoring it. Took the 1 wire alternator off and I am putting back the generator,,, here's my problem. The regulator has 3 terminals -gen- -bat- -L-. I have the bat terminal hooked to the ameter and the L hooked to the light terminal on the ign switch... Is this right????? ? Thanks in advance, John
jld
09-19-2001 08:19:37
 Re: Oliver 77 generator wiring help in reply to JOHN, 09-18-2001 17:31:36
Diagram is in Op manual. B goes to ammeter. L goes to centermost terminal on rotary switch. The spade sits flat vs around the perimeter. Korves Bros has fuse block, rebuilt rotary switch and wiring harness if you need them.
John
09-19-2001 13:52:45
 Re: Re: Oliver 77 generator wiring help in reply to jld, 09-19-2001 08:19:37
Thanks, thats what I needed to know!!!
