Cockshutt 30 rebuild
Jud Lupkes
09-18-2001 10:56:21
I pulled this thing out of the grove. Family tractor. Engine completely shot. I have a replacement block. What next? Get the crank checked and turned? Do the new main bearing come with overhaul kit? Attach the block to the tractor or put the crank in first? Help, please!
Dan
10-04-2001 21:58:53
 Re: Cockshutt 30 rebuild in reply to Jud Lupkes, 09-18-2001 10:56:21
Hi ,
I rebuilt a 30 . It was a basket case ,The rings were to have a gap of .009 but had .130 , no kidding . And it still ran but smoked out every black fly and mosquito within 2 miles .
One thing to watch for -- and this is important -- There are two bolts that mount the cam shaft ,one is normal 1 1/2 " long about ,but the other one is about 1/2 " long with a hole lengthwise through the middle . DO NOT LOOSE THIS BOLT ! It was replaced before I bought thje tractor , and the oil pressure went up to about 175 lbs . This is the oilspill line and oils the timing gears etc.
Anyway , it works good now .
