The latest project
Shep
09-16-2001 17:40:41
Well I thought you guys might enjoy seeing what I am attacking for my latest project. As most of you know the 310 Waukesha in my 1855 has been suffering for quite some time and finally the power really began to go, so I figured it was time for a change. Considering I had worked on this engine three times this year already I decided to break down and put the 5.9L Cummins into her, just like I did with my 1850. So far I have her all tore down and am ready to do some paintin before installing the engine. I hope this will end up being as good a tractor as my 1850 was when I got done with it. Keep checking back on photopoint for more updates. Enjoy!!
Sam M.
09-20-2001 13:22:18
 Re: The latest project in reply to Shep, 09-16-2001 17:40:41
Good luck with the 1855 . Please keep us up to date on developments , problems etc . I have an 1855 with a 1955 engine that , so far , is running well but you never know . Your description of how well the 1850 runs makes me want to go ahead and put a Cummins in the 1855 . It would be great if you could keep a diary or journal of what do you or at least list the problems that you ran into with the conversion and how you solved them . Also for future reference where did you get the new engine ?
On another issue , the rear crankcase oil seal on my 1850 is leaking oil into the bell housing and is going to have to be replaced . It has a hydrashifter so the only way to get to the seal is to pull the entire engine out of the frame . The engine is a Perkins . Other than leaking oil into bell housing the engine is real strong , cranks real easy even in cold weather and is easy on fuel for a 95 hp engine and only has a little over 3000 hours . I have removed oil pan and all bearings , rods , oil pump , etc look real good . I am going to go ahead and replace front crankcase oil seal and gasket on timing gear , pilot bearing and throw out bearing and look at clutch plate and pressure plate for possible replacement . Anything else you think I should look at while I have everything pulled . Any comments you or others might have would be appreciated . Please feel free to contact me directly at [email protected] .
Shep
09-21-2001 06:34:41
 Re: Re: The latest project in reply to Sam M. , 09-20-2001 13:22:18
Thanks for the comments Sam. I am trying to keep pictures and a log of everything I am doing in my cummins conversions. The 1850 was really not bad to do at all, but I am already seeing several things that are going to make the 1855 conversion harder. I am trying to keep as much information about these conversions as I can for the next time I do one, or to help you guys out here on the board if you need help.
I got my Cummins engine out of Oregon, but you can get them at a lot of different dealers all over. I am assuming that your rear engine seal is leaking out into your bell housing on your 1850. You are correct in that the only thing you can do is pull the engine, drop the oil pan and fix the seals. I would defenatly replace the front seal while you are there, and look for any other seals that are leaking on the engine or the three speed. Not a pricy job, it will just take time. The Perkins engines are not hard to pull out, but there are a few tricks if you have never pulled it out before. E-mail me if you need any help.
ShepFL
09-17-2001 17:18:47
Hey Shep!
Looks like ya got another great project ahead of ya!! As usual I am sure you will do a great job! Need some advice on how you convince the "other half" to invest in such things. Thanks for sharing
Still in the weeds. . .
Woody
09-16-2001 18:44:50
Shep, I believe you to be a talented man in the restoration and rebuilding of the late model Olivers. Several weeks ago I posted a note about my 1850 Gas tractor. We are pretty sure that the main bearing is bad. I hate to get rid of the tractor. Is this a big job to change and fix. as well as overhauling the engine? I overhauled a Farmall M several years ago myself and was successful. Is an 1850 Gas overhaul something a Novice can do? Your comments would be appreciated.Thanks in advance.
Shep
09-17-2001 05:19:48
 Re: Re: The latest project in reply to Woody, 09-16-2001 18:44:50
Woody, if all you have done is spun a bearing, I would open the oil pan and drop some of the main bearing caps (you can do this with the engine in the tractor). You may get lucky and find the spun bearing and be able to replace the bearings and not have hurt the crankshaft(It happens). If the crankshaft is damaged and you have to take the crankshaft out you are going to have to pull the engine. It really just takes more time than smarts but you do need a place to get the tractor in the dry, like a shop and a loader or lift that can lift the engine and hydra power out of the tractor. If all you have to do is pull the crankshaft and put new bearings in I would think you could do it yourself as long as you have a way to safely get the engine out. If you have to rebuild the entire engine and have never done one before you had better let a shop do it, or bettre yet have someone help you that has rebuilt an engine before. I really dont think that your problem would cause you to throw the tractor away if that is all that is wrong. If you have more questions you can e-mail me and I will be glad to help.
Larry from Maryland
09-16-2001 18:29:27
Hey shep i saw a 1850 and 1950 weatland at the Arcadia show on saturday.They both had for sale signs on them.Both had much wider frames than the rowcrop models.At first i thought they where yours.I did NOT get the guy's name or number.
ShepFL . . . just my luck
09-17-2001 16:21:40
 Re: Re: The latest project in reply to Larry from Maryland, 09-16-2001 18:29:27
And I got some extra $$ in the tractor fund. Been "wanting" a 1950. No # eh? Better luck next time.
Shep
09-17-2001 17:49:31
 Re: Re: Re: The latest project in reply to ShepFL . . . just my luck , 09-17-2001 16:21:40
Dont lose hope just yet, the other feller that told me about those tractors said he had the guys number. Let me talk to him and see if we can find him. Jump back in the weeds and I will get back to you soon. :-)
Shep
09-17-2001 05:24:17
Someone else told me about those tractors that were there too. They musta been massive, sorry I missed them. I have always wanted to tackle a 1950 with that big Detroit as a project. Better let the tractor fund catch up a little from the last two projects first though. Wonder what Wheatland tractors were doing on the east coast?? I thought most of those were in the mid-west. Thanks for keepin us posted Larry. Keep searchin the weeds for tractors.....
Larry
09-17-2001 09:13:35
 Re: Re: Re: The latest project in reply to Shep, 09-17-2001 05:24:17
I should have added to the post above,that the for sale signs had no numbers or names on them so there was no way to contact the guy unless he was standing there. Many times i have thought about selling my 2655,but this year i had to use it.Now thats something thats massive.
