White 2-105 Hydraulic trouble
Craig A Tull
09-16-2001 12:15:52
Well my brother-inlaw has had it with his 2-105, the hydraulic pump burned up and the replacement one followed in short order. He decided to just about give it away-$900.00. So I figured if anyone was going to screw him, who better than his brother-inlaw. Do these have a history of failer? He said he cleaned out the system as good as posible including the flow valve. The last time I looked at it I thought a gear pump could have been installed in place of the piston pump, has anyone heard of this? Does the cab need to be pulled and the hydaulic sump pulled and cleaned?
Thanks
Craig
Larry
09-16-2001 18:21:16
 Re: White 2-105 Hydraulic trouble in reply to Craig A Tull, 09-16-2001 12:15:52
I have allmost the same problem.The system is closed center so all valves must be changed to use a gear pump.The mounts and drive shaft are a standard industry size on the pump.Unless you have a donar tractor,plus lots of skill makeing your own parts i would advise not makeing that change.The external remotes are easy to change but the 3point is tough not to mention all the other stuff.I completely cleaned mine and still had metal parts getting past the new filter for months.All the valves stuck on mine and had to drive them free with a punch.Unfortunatly something is letting some of the flow past to the tank.This is makeing the pump work more than it should.
