Super 77 diesel oil pressure
westville
09-15-2001 16:31:10
When I got the tractor I changed oil and oil filters. The tractor runs fine and has 12 to 18 pounds of oil pressure according to the gauge. When I went to change the filters and oil the second time the filters were both clean and did not seem to have oil in them. Can someone tell me what is happening? Did I buy the wrong filters? Is some bypass stuck open? Help
jld
09-16-2001 06:56:45
 Re: Super 77 diesel oil pressure in reply to westville, 09-15-2001 16:31:10
Have to remove the filter base to know for sure, but very likely the filter base return passage and the block return port are plugged with dirty stuff... Remember the old oil filters with cotton media - the stuff that plugs it up will look like cotton and dried oil. Replacement filters have paper media.
The filter base has an orifice plate the allows some oil to be filtered (not a full flow filtering system) and then flow straight back to the crankcase (return port is near the camshaft). When the passage is plugged, you have better than normal oil psi. When you unplug it, hopefully, you will still have normal psi.
When you installed new filters, they don't fill right because oil can't flow through to the return.
Can provide photo's if you need, but simply remove the 3 bolts securing the filter base and take a look. If you don't want to wait on a new gasket, you can cut your own easily.
Hope that things are still good internally. Mine was - just somewhat dirty. Only wear seemed to be at the rocker shaft.
