Oliver OC-3 43 Ind
Chad Sutter
09-10-2001 11:53:28
I'm the recent proud owner of an Oliver OC-3 43 Industrial and just got it up and running yesterday. It has a Ware loader which is now working well; except for two leaky cylinders. I need some advice or information on the oil drip (run) I'm getting from the back of the block. There is a 1" pipe at the right rear of the block that is dripping oil. The faster I rev it up, the more it seems to drip, or run as the case may be. Now the dipstick says the oil is at the correct level, I think. That dumb little collar on the stick moves up and down over an inch where the stick is split into three segments (who's brilliant idea was that?). I'm getting quite a bit of blow by from the breather/filler as well. Have I over filled the oil? Any input is greatly appreciated.
DaveInMI
09-10-2001 17:35:33
 Re: Oliver OC-3 43 Ind in reply to Chad Sutter, 09-10-2001 11:53:28
The engine oil and hydraulic oil in my OC3 are seperate systems.
