Oliver 1850 Desiel
Chris Mauk
09-06-2001 07:52:08
Hard to start. Any possible answers? Thank you.
Zeus
09-06-2001 10:48:22
 Re: Oliver 1850 Desiel in reply to Chris Mauk, 09-06-2001 07:52:08
A few:
Lack of compression, cranking speed too slow, air cleaner blocked, fuel not reaching injectors, incorrect grade of fuel, incorrect timing, also one of the most overlooked factors: is there fuel in the tank?
These are just a few things that come to mind. Hope they give you something to go on.
Shep
09-06-2001 13:30:03
 Re: Re: Oliver 1850 Desiel in reply to Zeus, 09-06-2001 10:48:22
Zeus is right, my only advice above that is to check the easy stuff first. Bad fuel, clogged air cleaner, all things that can be easily checked before tearing into an engine.
