Oliver 66 won't start
Rustin
09-05-2001 14:44:18
I've got an oliver 66 that just got a brand new ignition and has spark. The timing is correct and the carburetor is feeding fuel to the engine. Tractor still will not start. It has compression and does nothing. Anyone know what is wrong?
Dean
09-05-2001 15:06:19
 Re: Oliver 66 won't start in reply to Rustin, 09-05-2001 14:44:18
Try to start it. Then immediately pull a plug. If it's wet, you have no ignition; if it's dry you have no gas getting to the cylinders.
Or, carefully squirt carb cleaner in the intake when you crank it. Same deal; no start means no spark; if it starts, there is no gas getting to the cylinders.
Scott Green
09-05-2001 22:27:28
 Re: Re: Oliver 66 won't start in reply to Dean, 09-05-2001 15:06:19
I'll add one more thing to Dean's reply. If you have spark in your distibutor(points) , let me ask you this; Did you have your distibutor out? Did you put it back in at 180 degrees off?
Rustin
09-06-2001 16:08:18
 Re: Re: Re: Oliver 66 won't start in reply to Scott Green, 09-05-2001 22:27:28
Thank you for the replies. Found out i had a blockage in the oil bath filter.
