1750 gas PTO won't shut off ?
Monte Gullion
08-30-2001 18:08:32
I am getting ready to purchase a 1750 gas in great shape except I can't figure out how the PTO shuts off. The owner inherited it so he's no help. I figured it was the lever to the right of the seat with the push button. I move the lever both ways but nothing happens, the PTO is always on. Can someone help? I am wondering if this is a common problem or maybe a major one. Cockpit error ?
Craig A Tull
08-30-2001 19:14:10
 Re: 1750 gas PTO won't shut off ? in reply to Monte Gullion, 08-30-2001 18:08:32
Monte, Your 1750 has a twin disc type clutch. You should be able to feel it "click or pop" as it is engaged and disengaged. It also has a brake that is probably not adjusted correctly. I agree with Ryan that an operator nanual be acquired asap. Your PTO clutch handle can be on ether side but if there is a handle on both sides with a button on top ( not the hydraulic controls ) the one one the right should be a two speed selector. If its the brake adjustment pulling slightly to the rear on the handle should stop the PTO.
I hope this helps
Craig
Ryan
08-30-2001 18:38:39
on my 1650, the pto is on the left, or your left hand would run it as you are in the seat. pto should stop with lever pulled back to rear of tractor. there is a link to manuals on the side of this page, I would suggest you get one, it will make life easier on you and your tractor.
B White
08-31-2001 07:35:50
 Re: Re: 1750 gas PTO won't shut off ? in reply to Ryan, 08-30-2001 18:38:39
I bought an 1800 last summer with the same problem . My 1800 PTO has steel clucth plates and friction plates. The steel plates had sometime in the past got hot and warped. The result was that the PTO would not shut off regardless of the position of the lever. I had to rebuild the PTO with new steel plates and friction plates. If this is the problem with this 1750 I would ask for an appropriate reduction in price.
Craig A Tull
08-31-2001 14:06:41
 Re: Re: Re: 1750 gas PTO won't shut off ? in reply to B White, 08-31-2001 07:35:50
How much did it cost to rebuild the clutch?
Thanks
Craig
