Oliver ID
Whiskers
08-25-2001 09:26:13
Can anyone helo ID this tractor? It has an unstyled radiator with OLIVER cast into the upper tank. There is not a tag anywhere that I could find. It is 4 cyl gas, narrow front and came with 40" rears. The wheels are cast with a removeable pressed steel rim. The axles are splined. It is possible that this tractor is put together from parts. I was told by the current owner that he thought it was a 70. Thanks for any help. BTW, the tractor has not run for years and is stuck.
Lee
08-25-2001 14:24:55
 Re: Oliver ID in reply to Whiskers, 08-25-2001 09:26:13
The 70 is a six cyl. Sounds like it is probably an 80 row crop. Is it three speed or four? Does it have Hart Parr on the left side of the block behind the manifold? If so, then it could be an 18-27, but they usually had Hart Parr also on the front or the radiator in smaller letters. The 80 also had 1/4 bigger rear axles than the 18-27. The 18-27 rear axles are the same size as the 70. The casting on the bolck would probably be C -100B.
