Oliver 77 battery table -- rusting away
Cowboy Bill Wat
08-22-2001 05:09:58
the battery table in my oliver 77 is fast rusting away.
so what do i do? i'm not a sheet metal man, nor a body man.
suggestions???
Jerry B
08-22-2001 05:56:26
 Re: oliver 77 battery table -- rusting away in reply to Cowboy Bill Watts, 08-22-2001 05:09:58
You will have to contact a body shop or sheet metal technician in order to repair/replace the battery tray. You may find some one who can just make you a drop in replacement that you can bolt/pop rivet into place.
I made mine from a thick sheet metal,trimmed away the old battery tray leaving enough edges to weld to, and simpley welded the new one into place. Works fine.
Cowboy Bill Watts
08-22-2001 06:09:05
 Re: Re: oliver 77 battery table -- rusting away in reply to Jerry B, 08-22-2001 05:56:26
jerry, serious inquiry.....
would you consider making me one that i could drop in an bolt up (i cannot weld)?
how much would you charge if you'd do it?
Jerry B
08-22-2001 08:17:24
 Re: Re: Re: oliver 77 battery table -- rusting away in reply to Cowboy Bill Watts, 08-22-2001 06:09:05
Let me measure the battery tray and make sure I still have enough metal. Pretty sure I do. Email me and we can forego the posting here.
