OC3 stuck clutch/HELP
Dave
08-19-2001 13:33:12
Hi, I am in the process of reassembling a Oliver OC3. I haven't put the tracks on yet. I fired it up just to check everything out and have found the clutch is stuck. If I try and put it in gear it grinds. It has been a year that it is sitting, before that the clutch was fine.
Any quick fix ideas or advice will be appreciated.
Thanks, Dave
Larry
08-19-2001 17:46:11
 Re: OC3 stuck clutch/HELP in reply to Dave, 08-19-2001 13:33:12
Try to break it loose.Start engine with trans in high gear, then push in clutch and yank on both brakes at the same time.Make sure the sprokets wont touch anything. Or you could put the tracks on and run up against a tree.
