770 ind: atf leak betweenenginet/converter
conrad
08-17-2001 17:39:36
i own 770 ind.w diesel reverse/torq trans.it has loader/hoe.1st what seal would that be leaking.2nd where can i buy a new one.3rd does anyone have a service manual so they can e mail me pictures of the break down of the seal /trans.4th it looks like the engine would have to be pulled out,because everybody tells me the body splits a part???..and if i had to pay for this job how much do think its going to cost me thanks for all your help conrad
Bob K.
08-17-2001 19:36:50
 Re: 770 ind: atf leak betweenenginet/converter in reply to conrad, 08-17-2001 17:39:36
If you are leaking ATF from in between, I'd say it was the front shaft seal on the rev-o-torq. I have a unit from a 770 out and sitting on my bench, and will look at the seal to see if there is a part # on it. It probably won't be hard to find a seal, but putting it in will be a real chore. You should plan on yanking the motor. I have somewhat of a breakdown of the R/T unit that I downloaded off this site last year, and will try to E mail it to you...good luck, BK
