Low oil pressure problem with Oliver 88
Richard holtz
08-13-2001 09:52:15
I have a 1953 Oliver Row Crop 88. The tractor sat for over twenty years before it came to me. After a little work, I got the machine running. One problem, the oil guage only showed 5-15 PSI at idle and at running speeds. I replaced the guage and have blown out the lines and still remain with the low oil pressure. There is a crack in the engine block although it runs a long a water jacket so i don't think it is what is causing the pressure problem. Any ideas?****Richard
vern in ne ks
08-14-2001 07:09:28
 Re: Low oil pressure problem with Oliver 88 in reply to Richard holtz, 08-13-2001 09:52:15
5 to 15 lbs is normal. Bearing clearances have nothing to do with oil pressure in this engine. This engine has a galley along the inside with small holes that squirt oil onto the rods and mains. That way, no matter how loose the crankshaft bearings are, oil pressure remains constant.
Scott Green
08-13-2001 13:05:21
5-15 pounds of oil preasure is normal for that tractor. The fleet line Olivers do have low oil preasure. In the manual , they will mention them very same numbers when talking about the oil preasure range(5-15). And like Dean says , bad seals/bearings , weak spring in the oil bypass chanel , scored oil bypass cup , etc..
Dean
08-13-2001 10:59:00
The most obvious cause is excessive bearing clearances. A worn pump is another.
