50 cockshutt weigh less
buda
08-07-2001 19:17:55
How light can a 50 cockshutt or E-5 co-op get with out stripping gears and ect?
D Neubert
08-09-2001 06:09:10
 Re: 50 cockshutt weigh less in reply to buda, 08-07-2001 19:17:55
mine weighs 5200 with 24.5 x32 tires and std. wide front end
Kent
08-08-2001 04:40:10
Buda, I really don't know how close to original you have, but with the cast rear wheels and cast front wheels gas is 6041 lbs and diesel should be 6163 lbs (Nebraska test J for my data) And as far as gears go I would think the lighter you go the better they will hold up. As long as you have a good clutch and don't go nuts. Kent
buda
08-08-2001 08:00:14
 Re: Re: 50 cockshutt weigh less in reply to Kent, 08-08-2001 04:40:10
I meant not wanting to pull out any gears or turning them down (thinner) on a lathe.
