Oliver Super 55 Steering Column problems
Dave
08-06-2001 18:51:53
I'm looking to find jpg. photo of the steering column from the Oliver Super 55 (1958) Repair Manual. I have my column completly ripped apart due to bearing failure and want to make sure it goes back together properly (I don't want any extra pieces hanging around when I'm done). If anyone has photos from the manual that can be emailed to me it would be greatly appreciated. Also, if someone can let me know the bearing numbers I would also appreciate that gesture.
Thank you in advance for your time.
Dave
[email protected]
Paul Stanley
08-07-2001 22:13:45
 Re: Oliver Super 55 Steering Column problems in reply to Dave, 08-06-2001 18:51:53
go to this link to my photopoint album list. There is one for Super 55 steering.
Paul Stanley, Part #s
08-08-2001 22:03:19
 Re: Re: Oliver Super 55 Steering Column problems in reply to Paul Stanley, 08-07-2001 22:13:45
The part numbers for the bearings are:
Upper Shaft Bearing: 1ES-6779
You will need two sets of the following to go above and below the Steering Gear.
Cone, Steering Gear Worm Thrust Bearing: 1L-6769
Cup, Steering Gear Worm Thrust Bearing: 1L-6770
A Agco dealer should be able to cross reference from the part numbers for you.
