Wiring Help Needed!!
DKaiser
07-28-2001 07:44:12
I'm trying to figure out the wiring on my 99 and I have a few questions. I have the tractor wired so that I do get power up to the coil and the tractor will run, but I have a terminal on the voltage regulator that I do not know where it hooks to. There are 3 terminals on the regulator and the one maked F runs to the field on the generator and I have the one marked bat running to the amp gauge which in turn runs to the battery on the opposite post. I've got a two postition switch to operate the tractor and it's powered by a wire from the amp gauge that is connected to the same post that the wire from the bat terminal on the regulator is connected. I've got the switch wired so one position will power the coil and the other should power the coil and the lights. The questions that I have is where to run the wire from the L terminal on the regulator to, and how should the amp gauge be hooked. Right now I'm not registering any charge, but I don't know if that's due to the fact that the regulator may not be polarized. I'm not good with this wiring stuff and I'd like to get the tractor to charge. The tractor runs well and I haven't noticed and problems with the wiring yet. Any help anyone has would be greatly appreciated, thanks.
Delbert
07-29-2001 10:12:02
 Re: Wiring Help Needed!! in reply to DKaiser, 07-28-2001 07:44:12
All of my Olivers are positive ground, a common mistake is to wire the ground to the negitive terminal, also be sure the regulator is for a pos ground system there is a difference on some regulators. I bought an 88 someone changed to a 12 volt system and wired it with neg ground, they even put an external resister on a 12 volt coil. The tractor always started hard you needed to spin the engine. I changed all the wireing to the correct system, to the point of putting the coil terminals on the bottun like Olivers are and connecting the wires to the coil properly, in other words I wired the tractor like it should be, you cannot believe the difference in starting and running now, so a lot of little things sometimes mess up the whole thing. Just my 2 cents worth. Delbert
DKaiser
07-29-2001 15:14:53
 Re: Re: Wiring Help Needed!! in reply to Delbert , 07-29-2001 10:12:02
I know what you are saying about running better. We have a 90 that is still 6V and it cranks so slow. We had to replace the field coils in the generator of this 99 so we had them switch it to 12V and it really turns the tractor over. I bought a new coil with an internal resistor. I'm sure that's all hooked right, because I had an 88 that is converted over to look at. This 99 with the 12V system sure starts good. We were gonna check for spark after I monkeyed with the wiring and had the number 1 plug wire off and I hit the started and the thing wanted to take off on 3 cylinders just like that. I think anything that gets restored now by me will be convereted to 12V. It's a pain when the 6V won't start the tractor. Thanks everyone for the help.
Larry
07-29-2001 06:40:13
The L post is a high charge post for the lights.Unless you plan on useing them alot leave it off.There should be 4 posts on the regulator.F goes to the F post on the generator.The B to the amp guage.The A which is sort of on the bottem goes to the A post on the generator.To polarize touch a wire to the A and B posts.
Scott Green
07-29-2001 10:21:12
 Re: Re: Wiring Help Needed!! in reply to Larry, 07-29-2001 06:40:13
Hi Larry , here is a question I have for you. My brother has a 12V battery in his Oliver "88". A 6V voltage regulator , and he thinks a 6V generator. The tag on the generator doesn't mention 6 or 12 volt. He says it always charged OK in the past. Can this be possible? Would a 6V generator charge a 12 volt battery? Or does he have a 12V generator. I know his old voltage regulator is a 6V , because it is stamped on the bottom. Maybe the different voltage components is the reason he started having trouble in the first place. If the generator is 6V , would it charge a 12V battery if a new 12V voltage regulator was put on it? What do you think? Any ideas on how to tell the difference between 6V and 12V generators?
Larry
07-29-2001 13:11:50
 Re: Re: Re: Wiring Help Needed!! in reply to Scott Green, 07-29-2001 10:21:12
I read the tag to tell them apart.A 6V wont charge up to 12 volts, but they can be turned up higher. A good 12 volt battery will spin a 6V starter evan if not up to 13.6 which would be full voltage.People used to use 8V battery's and turn the regulater up to 9.5 volts.This maybe what someone was trying to do. Some old 6V stuff are not marked for voltage because 12 volt had not come out yet. But 12 volt stuff is allmost allways marked.
Scott Green
07-29-2001 13:22:18
 Re: Re: Re: Re: Wiring Help Needed!! in reply to Larry, 07-29-2001 13:11:50
Good point Larry , Why would anyone mark a generator "12V" if it wasn't around yet. It makes sence that they may have been trying to use 8V battery. Thanks , Scott
Dean
07-29-2001 12:06:25
A DMM set to DC voltage scale with the engine running.
Scott Green
07-28-2001 18:29:53
Yes , you need to polarize the voltage regulator in order for it to charge. Do not have the tractor running when you polarize it. If so , you will instantly smoke the voltage regulator. I only did that once. The "L" on the voltage regulator stands for lights. If you powered the lights in a different way , just leave the "L" terminal on the voltage regulator blank.
