Oliver 77RC w/ Tasmanian Devil in clutch
Karl Covert
07-27-2001 18:09:52
We swapped in a motor from a 770 gas into my 77. The 770 had the same problem w/ clutches. When I release the clutch pedal I sometimes hear a howling/grinding noise but the tractor does not move. Is there a problem w/ the shaft coming from the engine to the clutch. Maybe a loose bearing on the back of the engine causing excessive vibration on the throw out bearing/shaft assembly? Prior to swap clutch was fine. Peplexed in NY
Ronnie Skerik
03-11-2003 22:37:06
 Re: Oliver 77RC w/ Tasmanian Devil in clutch in reply to Karl Covert, 07-27-2001 18:09:52
My Oliver 770 has the same problem. It growls when I step on the clutch. I haven't gone into it yet to look at it, but was wondering if you found the reason for your problem.
Larry
07-28-2001 09:32:59
Sounds like the shaft is slideing togather or back too much, Check the small bolt that holds the rear of shaft to the trans.It should have a small part that sticks in.You may need to add another one on the other side.
