Front end loader
Scott Green
07-27-2001 17:20:55
My neighbor is looking for a loader to put on his Oliver "1650" tractor. He is just getting into the big round bales , and has no way to lift them high enough to put into the feeder ring. I put the add in different classifieds found on the computor. Any other Ideas? My other neighbor drives cross country with truck and trailer , so trucking may not be a problem , depending on the route being traveled. Thanks , Scott
Doug Holt
12-27-2001 18:36:31
 Re: Front end loader in reply to Scott Green, 07-27-2001 17:20:55
Looking for a front-end loader for an international M tractor narrow front end. Include a detailed diagram and/or photo if possible to build.
Chris Robinson
08-05-2001 05:16:02
We have a 1750 Oliver with a model 500 Koyker loader. Works great. Check for a local dealer.
dave2_85
07-28-2001 13:56:25
The Bush Hog "QT" series will fit. The Models 2845 QT and 3425QT are both listed to fit the Oliver 1650. The 2845 will lift 3100 lbs to 11 feet, the 3425 will lift 3800 lbs. SO if he has a Bush Hog dealer in the area, he is all set. There may be other makes that will fit i.e. Westerndorf, Allied, Kelley, etc. Hope this helps, Good luck!
