70 Oliver
Ken
07-23-2001 19:44:17
I'M back I need more info . how about toque setting on head bolts and rocker arm assm. and cold valve gap setting Thanks Ken
Zeus
07-26-2001 10:58:22
 Re: 70 Oliver in reply to Ken , 07-23-2001 19:44:17
Ken,
According to the official Oliver Corp Service Manual for the "70" tractors, the torque values should be as follows:
Cylinder head cap screws 62.5 (62 1/2) ft/lbs for all EXCEPT the CORNER cap screws on the spark plug side of engine; they should be at 50 ft/lbs.
Rocker arm assembly support cap screws 22 ft/lbs
Valve clearance (cold) for both intake and exhaust valves .010" - .012" with .011" being the exact gap to be aimed for
Hope this helps
Ken
07-26-2001 19:50:46
 Re: Re: 70 Oliver in reply to Zeus, 07-26-2001 10:58:22
Thanks to both with my H Farmall I had a I&T to check . I might See some smoke by the end of next Wk.
Jim T
07-25-2001 16:24:54
Ken, here's what my book says Head bolts...62ft. lbs.; except left front and left rear corner bolts- only 50ft. lbs. Rocker arm bracket nuts...22ft. lbs. Manifold nuts...25 ft. lbs. Tappet clearance... .011"COLD . Good luck Jim
