Original Lights for Rowcrop 66
Tom in Frankenm
02-24-1998 05:54:53
When I bought my '51 Rowcrop 66 (which is pretty well
done and ready to work) a few months ago, I got the
original steel lights. Some are pretty well rusty but are probably restorable. My question is, where do I get "lights". Two of the lights have been changed to
sealed beams, which are close, but not quite the right
size to fit in the housing. The other, has the original
reflector and socket for the bulb. Is there a "sealed
beam" light that fits in these lights? What is the number
and where can you get them?
For the time being, I'm using three $14 "utility" lights
like you would add to a combine, in black rubber housings. They work, light the way, but look stupid
on a tractor of this vintage. Sometimes you have to make a decision if the tractor is a tool, or a plaything and buy accordingly however.
Thanks,
Tom
Chad Sutter
02-24-1998 16:33:36
 Re: Original Lights for Rowcrop 66 in reply to Tom in Frankenmuth, 02-24-1998 05:54:53
Tom,
I've retrofitted a couple of old lights with new halogen H4 units by installing a socket inside the old housing- I've made a reflector out of a cheap stainless steel bowl (which needed to be buffed out to reflect). The light output was great- it's a bit of work though.
