Oliver 60 wheel weights
Ben Haag
07-19-2001 18:50:06
i have rear wheel weights and i found a set of front oliver wheel weights with the casting numbers starting with H wich is for oliver 60, but i cant figure out how they go on..any help?? and my oil pressure is sky high! i cant get it to gow down unless it idles. any help there???
B A Star
07-19-2001 20:43:19
 Re: Oliver 60 wheel weights in reply to Ben Haag, 07-19-2001 18:50:06
The front wheel weights were attached to the wheel with "J" bolts. They go through the openings in the wheel between the disc and rim. How much oil pressure do you have? Have you attached a Lb pressure gauge? The original gauge operating range is very low psi. I wouldn't worry about it.
