770 governor hunting
Chuck Hilton
07-15-2001 10:34:57
Just finishing a major amount of work on a Lull forklift (based on Oliver 770) only problem that remains is hunting or surging when throttling up. Carb (Marvel Schebler with adj main jet) was soaked several days in solvent all passages cleaned with wire and air. Idles great but varying load can set it into hunting when accellerating. Any ideas would be helpfull. Thanks Chuck
Bob M
07-16-2001 08:55:39
 Re: 770 governor hunting in reply to Chuck Hilton, 07-15-2001 10:34:57
Check the governor to carb linkage. If there is any stiffness, binding or worn pivots in the linkage it'll cause exactly what you describe. Check especially the carb throttle shaft - with the linkage removed the shaft should rotate freely with the lightest finger pressure. If not, find and correct the cause (bent shaft, bushings too tight, etc).
